Lifters - some questions ...
Old Apr 27, 2011 | 05:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I understand hydraulic lifters. I have questions on roller lifters ...
1) Does a roller lifter still get 'pumped up' with oil?
2) If not, does that mean that valve lash adjustment is more critical with roller lifters?
Hydraulic lifters get 'pumped up' with oil, and thus take up some of the 'slack' of the valve adjustment - in my mind, to a very small degree, this tells me that it's not a REAL technical issue to adjust valves when there are hydraulic lifters involved, since the oil 'pumping up' the lifter assists in making the total length needed (between rocker and cam lobe).
I also assume this is why for the last 18 gazillion years we have the "Great Turn Debate" - where some say 1/2 turn, some say 3/4 turn, some say 1 full turn ... after the valve stops ticking when adjusting on a running engine.
How does all this relate to roller lifters if they do not 'pump up' with oil?
Old Apr 27, 2011 | 06:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
On the inside, a hydraulic roller lifter looks just like a hydraulic flat tappet lifter.
Personally, when I tried adjusting my factory hydraulic roller lifters to 1/2 or 3/4 turn down with a ZZ4 cam, they would clatter. When I turned them a full turn down, they were nice and quiet. And, for what it's worth, the car ran quicker than it had before.
I would shift 1-2 at 6000 RPMs, and 2-3 at 5500 RPMs. It saw 6300 RPMs many times (usually on the freeway on-ramps when I was horsing around and not paying proper attention to the tach). Never complained. Haven't heard any complaints from the guy who bought the engine, either.
Old Apr 27, 2011 | 08:30 PM
Car: 1992 RS
Engine: Carbed 350
Re: Lifters - some questions ...
OK, cool. So, in essence, the roller lifters 'pump up' like a hydraulic lifter when the oil pressure is introduced, right?
Old Apr 27, 2011 | 08:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No... a roller lifter can be a hydraulic lifter.
There are flat lifters and rollers, and there are hydraulic lifters and solids. That means you can have hydraulic flats, hydraulic solids, hydraulic rollers, and solid rollers.
Old Apr 27, 2011 | 08:54 PM
Car: 1992 RS
Engine: Carbed 350
Oh, yeah - I know there are solids as well. But I'm under the assumption here that most stock configurations use a hydraulic type, whether roller or flat. So, my curiosities are settled now, thanks guys!
Old Apr 28, 2011 | 05:47 AM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
On my recent 355 build with a Lunati 54779 cam, I adjusted mine to 1/2 turn past zero lash (static adjustment when building the engine) and they are perfectly quite. It really depends on the cam and that is why a lot of people recommend adjusting the valve lash while the engine is running.
Old Apr 29, 2011 | 04:18 AM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
My understanding is that as hydraulic lifters still have a maximum length they can produce you still have to adjust your valvetrain so that they don't need to reach this maximum length ... if not you will get clearance between rocker and valve stem thus causing noise (and damage ?)
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
