Hydraulic roller lifters
Old Apr 28, 2011 | 06:12 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Question. I have a 1991 1pc rms 2 bolt main block that can accept hydraulic roller lifters. Can I use GM PN# 17120735 roller lifters in this block with a small base circle cam(custom XFI280)?
Old Apr 28, 2011 | 07:01 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Hydraulic roller lifters
do you have the (for lack of a better word) spider thing and the retainers that go with it?
i tried finding those lifters on gmpp. i couldnt. are the connected to eachother like other aftermarket roller lifters?
Old Apr 28, 2011 | 07:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The "small base circle" part concerns me. They aren't extended tops, so they may sink too far into the anti-rotation guides.
Old Apr 29, 2011 | 03:55 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
They are the old GMPP " 2nd design " LT1 lifters everybody was using
http://www.summitracing.com/parts/NAL-17120735/
Roller lifter of choice now is the LSX Lifter
$130 a set / good for 7K
http://www.summitracing.com/parts/NAL-12499225/
Old Apr 29, 2011 | 03:55 PM
remltr's Avatar
Aren't the new ls rollers shorter than the "old style" and may require a different length push rod. I already have this motor running and I think I have a bad lifter, just want to replace it. This engine is bored and stroked,5.7 h-beam rod with 3.75 stroke. SBC cam was recommended by comp for clearance.
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
