Spark plug gap on stock 350tpi
Old Apr 30, 2011 | 11:20 AM
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
I have been able to search up plenty of gap sugestions for motors running modifications and improved ignition systems, however i am unable to find a plug gap sugestion for the stock 9.3:1 350TPI out of an 88 IROC-Z
Old Apr 30, 2011 | 11:40 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Spark plug gap on stock 350tpi
Call Autozone?
Old Apr 30, 2011 | 02:02 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
35 thousandths (.035)
Old Apr 30, 2011 | 06:51 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
.035 is what i run. That is what stock calls for.
Old May 19, 2011 | 04:54 PM
scottishtransam's Avatar
Car: 1987 Trans Am and 2009 Jeep Patriot
Engine: 305 Tpi
Would a stock 87 305tpi be the same? using champion copper plus. My emmisions decal is long gone thanks guys
Old May 19, 2011 | 05:52 PM
TNT_Z28's Avatar
yes
Old May 19, 2011 | 06:29 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
I also use 0.035 on Autolite single platinum with modified 355. No issues. I also used 0.035 on my 1987 (LB9) 305 and it ran fine.
CG
Old May 19, 2011 | 07:16 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
anywhere from .35 to .40 will work just fine, stock actually calls for .42 if i remember right
Old May 19, 2011 | 07:20 PM
TNT_Z28's Avatar
stock is actually .035
Old May 19, 2011 | 08:06 PM
not that it matters
Old May 19, 2011 | 08:19 PM
Engine: 305 Tpi
Thanks guys .035 it was. got em all from above. No smog pipes helps
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
