What cam?
Old May 4, 2011 | 12:28 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
What cam?
My brother has a set of AFR 195 Street heads and I have a mid 70's splayed 350 block .040" fresh from the machine shop. We are thinking of building a motor for a 86 IROC with a 700R4. The block will be going back to the machine shop and getting clearanced for a larger crank.
This is being built on a $2,000 budget. I pieced together a descent bottom end that should sit us in the area of 9.7-9.9:1, Torker 2 intake and now I need to pick a cam. We want to avoid a retrofit setup and just stick with a flat tappet cam to save money (and since it's limited on the street).
I suggested something along the lines of a CL12-250-3 (240/246 @ 50, .507/.510" lift). I figure behind a 2,500 stall this can turn high 11's? Anybody have a better cam selection?
Old May 4, 2011 | 12:49 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: What cam?
Comp Cams Camshaft Selection Tool --> www.camquest.com
You might want to verify the oil pan fits. My mid 70s truck block was driverside dipstick pan, which I swapped to an aftermarket made for a stroker.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
