Summit 383 Block missing oil plug
Old May 4, 2011 | 12:51 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I purchased a summit 383 block for my new motor that I am doing. I was reading the other day that there is some type of oil plug that is taken out of the block during the cleaning process and is never put back in. Without this plug in there, I guess the oil will bypass the filter. What type of plug and size do I need to buy so that I can re-install it into my block?
Old May 4, 2011 | 01:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Summit 383 Block missing oil plug
1/2" on the 2 piece RMS blocks. I'm not sure if they changed it on the 1 piece RMS.
Old May 4, 2011 | 01:41 PM
never put back in
Pretty strong language there d00d!!
A more appropriate way to put it would be, "is often left out".
Definitely check, but you may well find that it's there. If you take off the rear main cap, you will see 4 holes. 2 are bolt holes. The other one on the pass side of the block is for the oil pump drive rod. The other on the driver's side is where the plug in question goes. Should be around 1" or thereabouts up in there. If you can look up in there and see a single horizontal hole in the side of that passage, and then the plug just past that, it's good to go. If you see 2 horizontal holes and no plug, then you need one. It goes between the 2 holes, right past a little step up in there.
Old May 4, 2011 | 01:58 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
So where exactly can I buy this 1/2" plug? Is it a certain type of plug?
Old May 4, 2011 | 02:32 PM
Any parts store.
It's basically a freeze plug. Might even BE a freeze plug, in some applications. It's also the same plug as the 3 in the front of the block around the cam. Should cost no more than a few cents.
Look before you buy. It may well already be there.
Old May 4, 2011 | 03:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This should help.
RBob.
Old May 4, 2011 | 09:11 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
So it's just a solid 1/2" plug that is pressed all the way into the hole?
Old May 5, 2011 | 09:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's a regular cup plug. The bore gets smaller at the installed location, so drive it in until it stops. Check that it's far enough that the holes aren't obstructed, though.
Old May 5, 2011 | 12:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can see it in the picture, up & right of the center of pic. The shiny piece in the oil passage. Note that it is a cup shaped plug.
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
