tps low voltage
Old May 11, 2011 | 01:57 PM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
tps low voltage
i got code 22 for low voltage on tps and started testing it. i get a good sweep testing the sensor on ohms and then when i pluged the conector in and started to test for signal voltage i get only .3volts all across the board from closed to wot. i have a 5 volt reference. any ideas on fixing this?
BumpaD82
Feb 26, 2016 02:57 PM
adelane
Sep 9, 2015 08:51 PM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
