strong fuel smell from exhaust at idle
Old May 12, 2011 | 08:55 PM
tubbytownsend13's Avatar
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
ive got an 87 iroc 350 daily driver i need help with. at idle with the motor cold or warm i get a fuel smell from exhaust pipe like burn your eyes unburnt fuel smell. car has new plugs wires cap rotor coil and coolant temp sensor. base timing is set at 6 degrees. i checked tps sensor for proper voltage readings and they were within spec.so now im pretty much stumped. if i blip the gas at idle it will rev nicely then pop alot out of exhaust. it doesnt blow any smoke though. please any help would be greatly appreciated.
Old May 12, 2011 | 09:12 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: strong fuel smell from exhaust at idle
6 degrees base? i would try a couple more degrees and see how that affects it make sure its unplugged when setting the timing.
Old May 12, 2011 | 10:46 PM
tbutle03's Avatar
have u check ur o2 sensor it could be bad and letting the car run rich.
Old May 12, 2011 | 11:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally Posted by tubbytownsend13
at idle with the motor cold or warm i get a fuel smell from exhaust pipe like burn your eyes unburnt fuel smell. if i blip the gas at idle it will rev nicely then pop alot out of exhaust.
Well you got 2 of 5 symptoms
Does it cough every time you pass a gas station?
Does it ride kinda rough and not stop all that great?
Do the rear tires wear out quicker then the front?
If yes to all 5 I got some real bad news for you, what you got there is a Muscle Car. Seen it a thousand times.
They make a special car for folks who find it to be a problem, its called a Prius.
sorry, its late
Old May 13, 2011 | 10:42 PM
Car: 87 iroc
Axle/Gears: stock
i had a 84 z with a swapped in 355 and a 750 holley....ran like a beast...never smelled like fuel at idle when the carb was set right....
all the computer crap is confusing me thats why i asked the questions in the first place....im gonna check the o2 sensor tomorrow.....just gonna throw a new one in. car also takes forever to warm up and doesnt seem to enter the magical "closed loop" like it should until its been driven a good fifteen minutes...getting tempted to ditch tpi
Old May 13, 2011 | 10:45 PM
Car: 87 iroc
Axle/Gears: stock
emission sticker underhood said initial timing should be 6 degrees with esc plug disconnected so thats what i set it at...it was at 12 when i got the car....mind you it sat for 3 years with a bombed trans and other issues...the motor has ***** just doesnt like idling where it should
Old Dec 10, 2012 | 05:20 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
I have the same smell problem with 350ci heads cam carb bolt ons I think the fuel cell needs a cleaning Im running out of thoughts and yes my car has been stored for long time
Old Dec 10, 2012 | 06:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
wake up the dead in the wrong section, sounds like you need to learn to tune or re-jet your carb and look at the ccp.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
wayshegoes
Aug 17, 2015 12:00 PM
