Tach bouncing
Old May 16, 2011 | 08:49 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Tach bouncing
'88 L98/700R4.
I'm having trouble tracking this problem down. With the engine running, the tach bounces between 3000 and 4000 RPM. I just had the engine apart and while I was at it I removed the entire engine harness, stripped all of the tape and loom, inspected and repaired any damage I could find. I thought I would find the problem that was leading to the tach issue but I didn't find anything.
Has anyone had this problem before?
Old May 16, 2011 | 08:53 PM
Dialed_In's Avatar
Re: Tach bouncing
I should mention it's got a new cap, rotor, plugs and wires and runs fine.
Old May 17, 2011 | 06:52 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Tach bouncing
Bad connection at the coil for the tach signal? Hows the printed circuit board look?
Old May 17, 2011 | 07:32 AM
Dialed_In's Avatar
Re: Tach bouncing
Connection is tight at the coil and distributor plugs. Haven't pulled the cluster out to look at the circuit board.
Old May 17, 2011 | 11:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tach bouncing
Hit the electronics board here at TGO. Up in the sticky's is a long thread on fixing the tach driver board. A resistor goes bad which is easily replaced.
RBob.
Old May 17, 2011 | 11:42 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Re: Tach bouncing
I had to do the same fix on my tach that RBob is talking about- it was reading way high, but didn't bounce like you're describing. My bad for pointing you in the wrong direction. I didn't realize that was another symptom of the diode going bad.
FWIW, it's a really easy fix. If you've gone through your wiring harness, the fix will be pud for you.
Old May 17, 2011 | 12:04 PM
Dialed_In's Avatar
Re: Tach bouncing
Great, thank you both. I will get busy.
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
