starts and dies
Old May 17, 2011 | 02:33 PM
chip655's Avatar
starts and dies
I have a 90 camaro rs 3.1 it won't stay running it starts runs 2to3 sec and dies sometimes it will run for 3to5 sec but if you give it gas it dies.does anyone know whats wrong with it changed tps,map,fuel pump,ecm. you cankeep it running on starting fuel
Old May 17, 2011 | 02:54 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: starts and dies
Check your work. Why did you replace your ECM? What was the problem that led you to that conclusion? That's quite a list of parts. Were they all actually bad? What problem have you been chasing? I suspect that there is a problem with either your VATS system, or fuel pump control circuit that's causing it to start and stall.
Check fuel pressure, injector pulse. Check each as this problem is happening by watching them while the engine starts and as you let off the key to run. Does any of them drop off as soon as you release the key?
Old May 17, 2011 | 03:03 PM
chip655's Avatar
Re: starts and dies
i just got the car off my cuzin and they put all the parts on it what is the vats fuel pressure is 40psi
Old May 17, 2011 | 03:08 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: starts and dies
Vehicle Anti Theft System, or Passkey. It's a system that can disable the starter and the fuel injector control in the ECM if you try to start it with the wrong key or if it has a malfunction.
It sounds like someone's been throwing parts at this car trying to solve a problem. Has the start and stall been the issue all along? Perform the checks as I descibed them and tell us what you find.
Old May 17, 2011 | 03:14 PM
chip655's Avatar
Re: starts and dies
the car set for a lil bit when my cuzin started driving it for a few days he started it and drove it one day and when he shut it off to test drive a new car he came back and car wont start and so this is what its doing
Old May 17, 2011 | 04:49 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: starts and dies
I've been through this more than once and every time I hope it's not the injectors. But it's always been the injectors. Take off the upper plenum and check the resistance on the injectors. They should all be around 13ohms give or take about 1 and they should all be more or less the same. If this isn't the case get a new set. But not GB remans from RockAuto!
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
EFR2000
Aug 18, 2015 08:54 PM
