Motor leaking oil after build
Old May 17, 2011 | 08:10 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Over the winter I put new heads (aluminum) with a comp 503 cam and stealth intake manifold. After several weeks of oil leaking from what was thought the intake, it is leaking from the passenger side head (by where the oil pump kicks oil up). I have MLS gaskets and wondering if anyone had this problem.
Old May 18, 2011 | 10:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Motor leaking oil after build
Pressurized oil doesn't go through the head gasket anywhere.
Old May 18, 2011 | 06:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You sure it's not the valve cover gasket or the rear manifold end seal?
Old May 22, 2011 | 12:53 PM
Transmission: 700r
Yea I Checked those already and replaces manifold (Three times). It was leaking from the heads to the block because my block has some damage to the corners from normal wear. I had MLS gaskets on it and it didnt seal right. Sucks took it all apart again
Old May 23, 2011 | 12:39 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Surface finish for MLS gaskets has to be fine. Any deep cuts or imperfections will create a leak. Some users paint the MLS gaskets with copper coat or equivilent gasket sealer before install. This is not recommended by any of the MLS manufacturers and may affect the intended performance of the gaskets.
TheExaminer
Aug 26, 2015 04:59 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bamaboy0323
Aug 15, 2015 07:20 AM
