Using a key without a chip?
Old May 23, 2011 | 11:53 AM
RSCamaro350's Avatar
Hi, everyone! I couldn't find anywhere else to post this:
I have a 1990 RS with a carbureted 350. I have a %100 chance of loosing my keys sometime in the near future. If I got a key made without a chip shouldn't it work without the ECM? Just wanted to know before I pay $100 for another key.
Thanks!
Old May 29, 2011 | 10:54 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Using a key without a chip?
As long as VATS is completely removed or bypassed, the non VATS key will work.
Old May 29, 2011 | 11:02 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can supply a ground source to the starter enable relay (the black with yellow stripe wire) and that will eneable use of a regular cut key.
Or, you can go get a spare made at any ACE Hardware store for $25 (probably True Value as well).
Also, you can get VATS blanks on ebay - just have to know what resistor is in your key (measure pellet with a digital ohm meter). Then have any key cutter cut the blank to match your key.
And, you can carry a 3ft chunk of 10 gauge wire with you, and a spare regular key - insert key and turn to run, then jump the starter (purple wire terminal) off the battery positive.
Old May 29, 2011 | 11:20 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The above is of course assuming that you are not using the factory ECM with VATS fuel enable.
Old May 29, 2011 | 11:51 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
http://www.austinthirdgen.org/index.php?pid=41
The chart pic should be revised with is chart soon to include Digikey.com resistors. Not the only place to buy them, but is a good source instead of searching.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
djmarch
May 8, 2016 11:32 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
