Throttle cable attachments
Old May 24, 2011 | 04:05 PM
Broone115's Avatar
Hey guys, I need help here im confused, On the throttle body there are 3 cables that come off it, the throttle, the tv cable and and another one that goes to a rubber pump thing, what is the rubber pump looking thing? and should it be pressed in when I press on the gas or should it not be moving at all? because the way the cable is hooked up to the TB with the long oval type connecter, when the throttle opens it just passes through the opening, not engaging the cable to press the pump thing. Is this right? because I know on my 1990 K5's 350 it had the same pump looking thing and it was pressed in everytime you step on the gas. so im kinda confused, Thanks in advanced guys!
oh by the way its a 92 350 TPI
Old May 24, 2011 | 04:11 PM
luvmy64's Avatar
Re: Throttle cable attachments
Cruise control.....
Old May 24, 2011 | 11:41 PM
formula 89's Avatar
Car: 89 formula,92 firebird
Engine: 91 355 tpi, 3.1
Transmission: 700 R4
Axle/Gears: 342 posi,
if u can push in on the diaphram of the cruise servo and the throttle body opens up ur fine
Old May 26, 2011 | 07:19 PM
Broone115's Avatar
okay thanks
my86bird
Oct 23, 2015 12:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Nick McCardle
Sep 10, 2015 08:36 PM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
