Possible ground wire problem,
Old May 28, 2011 | 12:53 PM
NightHawk1824's Avatar
Car: 1991 Pontiac firebird #126 bandit
Engine: 305 tbi
Axle/Gears: stock 2.74's
HI i have a `91 305 tbi that i recently installed a lt1 cam, vortec heads and going to be switching over to carb, however i have run into a problem with some wires... I connected the braided ground wire to the back of the head along with two other loop grounds, i then connected the main battery negative to the block and the other ground from the battery to the frame was still attached. However if i touch the positive cable to the battery it will shoot sparks and will try to melt itself to the connection so i have some sort of bad wiring problem. any ideas of what i might be overlooking... i added pictures of each ground location thanks
ground wire to the frame
three grounds on the back of the passenger head, including the braided one to the frame
main ground to the engine
the usual spark show
Old May 30, 2011 | 02:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Possible ground wire problem,
The problem is with what the positive cable has attached to it.
Old May 30, 2011 | 10:58 AM
Engine: 305 tbi
what do you mean?
Old May 30, 2011 | 04:42 PM
five7kid's Avatar
Something connected to the positive side of the battery is grounded.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
