delayed starting
Old May 28, 2011 | 02:31 PM
TX T/A's Avatar
Car: 1992 Trans Am Conv.
delayed starting
Installed new fuel injectors,fuel pump,and fuel filter . Car take a few seconds to start. Runs good could it be a relay? Where is the fuel pump relay located?
92 5.0 tpi
Old May 28, 2011 | 02:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: delayed starting
Does the pump prime when you turn the key on?
Old May 28, 2011 | 09:22 PM
TX T/A's Avatar
Yes,I can hear the pump come on. The car just has to crank a few turns to come on.
Old May 29, 2011 | 01:03 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
often thats caused by the relay not working right or the ECM and not till the engine builds oil pressure does it kicks the fuel pump on and it starts.
Which isn't a bad thing really, to build oil psi before an engine starts.
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
overdriv
Aug 20, 2015 03:52 PM
92camaroJoe
Aug 13, 2015 06:07 AM
dhonda200
Aug 11, 2015 11:50 PM
