Wiring for an EFI sending unit
Old May 31, 2011 | 12:49 AM
daddy33's Avatar
Car: '85 Camaro
I'm working on my ls1 swap and doing my fuel setup at this moment. Since it was a carb before, I bought a EFI sending unit and put it in. Now on the sending unit it has three wires which plugs into a connector that's on the car located above the fuel tank. Would I run the fuel pump wire that I have from my ls1 harness to the slot on the connector that wasn't being used?
This was the old carb sending unit which has two wires:
This is the newer EFI sensing unit that has the wires:
This is the connector that the sending unit plugs into. Now the orangish color wire was the slot that wasn't being used when had the carb sending unit. So I would just run my PCM fuel pump wire to the orangish color wire right?
Old May 31, 2011 | 04:14 PM
daddy33's Avatar
Car: '85 Camaro
Re: Wiring for an EFI sending unit
Any lsx swap guys done this?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
