mass air flow question
Old May 31, 2011 | 01:21 PM
primaryfitness's Avatar
Car: 1989 Formula 350
Engine: 5.7l
Transmission: auto
Axle/Gears: BW 9 bolt w/3.27 gears
I have a 1991 Formula 350 and recently it started running real crappy. My question is when I unplug the mass air flow sensor the car runs great. I plug it back in and it runs like crap again. Does this mean I need a new sensor? I have no service engine light and tried replacing the mass air flow relay and it still wants to stall and runs rough.
Old May 31, 2011 | 01:47 PM
mlopezformula's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
Re: mass air flow question
Most likely it is the MAF, because when unplugged the car runs off the computer memory, and if you plug it, then its starts reading the values off the sensor. I read how to diagnose the problem here in the forum also, (just google how to check MAF sensor on third gen). hopefully that helps. Before you replace it don't forget to check you connectors.
Old Jun 1, 2011 | 12:31 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
1991? MAF? 350?
Old Jun 1, 2011 | 10:02 PM
Engine: 5.7l
Transmission: auto
Sorry,typo on my part,its a 1989
Old Jun 2, 2011 | 02:44 PM
jimmy198920's Avatar
Car: 1988 pontiac firebird
Engine: 2.8L
Transmission: 5 speed
I had the same problem with my 88 firebird I got some mass air flow cleaner at autozone and sprayed it and it made my car run better. Try the cleaner before u by a new one
Old Jun 2, 2011 | 02:48 PM
Engine: 5.7l
Transmission: auto
I tried the cleaner and it didn't help. Good news is I got a mass air flow sensor from Advance Auto and it cured the problem.
Old Jun 2, 2011 | 03:02 PM
Engine: 2.8L
At lest u got ur car running. I'm trying to figure out what is wrong with my firebird. I'm getting ready to go mess with it some more
Old Jun 3, 2011 | 09:10 AM
Engine: 5.7l
Transmission: auto
Well,it ran okay for a little bit then started acting up again but this time the service engine light came on. Pulled the code and says I have a faulty electronic spark control module.......guess its back to the parts store.
Old Jun 3, 2011 | 01:03 PM
Engine: 2.8L
That sucks. I would have the parts store test the electronic spark control module before u get a new one if they can test them. I would also have the tps checked out bc that can cause the car to run poorly. I've had to change mine 3 or 4 times already. I hope u can get ur car running right.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
