correct head gaskets
Old Jun 4, 2011 | 11:40 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
Because I am only around 300 hp, can anyone direct me to the correct head gasket on my 1st gen.350,bored 60 over. I just sent the stock cast iron heads(with stiffer dual springs for the cam I put in it) off for valve seals and anything else they need and I need to know which head gaskets I need for reassembly. Thanks.
Old Jun 4, 2011 | 01:03 PM
Re: correct head gaskets
HS7733-PTwhatever # they're up to now
Old Jun 4, 2011 | 02:03 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Buy the full gasket set KS2600 (68-79) for less than $50. It has the head, valve cover, intake, thermostat gasket which you will need plus other you may not need (for now)
Old Jun 4, 2011 | 02:04 PM
oramac91's Avatar
91 CAMARO350TPI.
New motor.alot of after marked to much to list.9.5 /roller cam/ headers/widewand/heads ported and polished/computer all stock.After i put the headers on and new exuast.its ignection knocking and turning pugs black.reading codes 13/32.PLZ HELP
Old Jun 4, 2011 | 06:38 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
oramac91, You're posting on a completely unrelated subject. How do you expect to get the help you seek for your drivability issue on a thread titled: "correct head gaskets"?
Start your own thread. In the meantime, when you installed the headers, what did you do with the O2 sensor and its wiring. If the O2 sensor circuit is grounded. Your car will run very rich.
Old Jun 5, 2011 | 01:35 PM
oramac91's Avatar
Hmm i get more feed back on none related forms.wierd hu?The o2 sensor was just moved to header.no rewireing or anything.what should have i done or should i do?
Old Jun 10, 2011 | 03:01 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Just got the news,both heads cracked.Same question except I am buying a set of new Prostar fully assembled heads and want to know if the gasket set (HS7733)I just bought for my cast heads will work with aluminum heads? thanks
Old Jun 10, 2011 | 05:55 PM
Yup
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
qz6lwp
Aug 20, 2015 08:10 PM
