New alternator battery still dieing?
Old Jun 4, 2011 | 07:09 PM
Deluca119's Avatar
This is odd, at first my battery was draining while started so i assumed it was the alternator because the previous owner threw one he had laying around in. So i swapped it for a new alternator. The battery still is not being recharged and when i turn on the lights or anything electrical the voltage meter drops slightly. Im gonna go through the grounds with a wire brush however, would anything else cause this? I ve heard of this dummy alternator light on the gauge cluster being the cause sometimes. Any ideas? Thanks in advance!!
I should mention that the battery threads were stripped a little by the previous owner.. great job ruining a new battery. I seemed to have made a temporary fix but its still not charging. Im thinking new terminals and battery, if that doesnt work im really out of ideas.
Old Jun 4, 2011 | 09:23 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: New alternator battery still dieing?
Check the charger wire with a voltmeter. Just to make sure you've got a good connection from the alt to the battery.
Old Jun 4, 2011 | 10:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have battery and alternator tested - any parts store will do it in the car for free. Badf alternator can kill a battery, and a bad battery can kill an alternator. And "new" alternator doesn't guarantee "good" alternator - I've bought plenty of new parts that were bad, including alternators.
Old Jun 5, 2011 | 09:58 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Try this, measure the battery voltage with the car off. It should be like 12V. Then start the car and remeasure the voltage it should now be like 14 V. If its not the charging system isnt working. Check that and well dig a little deeper depending on the results.
Old Jun 6, 2011 | 10:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
electric seat motors and cig lighter sockets can get gunky and drain power from the system, was a rash of hotrod fires a few years back from folks keeping orginal cig lighter sockets in the car.
So can a "miss" wired stereo system, if it has a re-moveable face plate, remove it every time. Most now are like a PC where it a soft power.
[On in my V8 car is like that, its wired hot on purpose [no keys needed to ROCK!!!] but even when its "off" its not, face plate has to be removed for a hard off.]
Old Jun 6, 2011 | 05:09 PM
Deluca119's Avatar
Finally got it straightened out after 4 days. Turns out one of the fuseable links were frayed, spliced in some new wire temporarily and shes recharging now. Phew
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
