350 Oil Leak Issue
Old Jun 5, 2011 | 12:48 PM
82RedDemon's Avatar
350 Oil Leak Issue
hey everyone I'm trying to pinpoint where my 350 is leaking oil but I just can't seem to find it
It's not a huge leak, just leaves a couple tiny puddles after being parked
I've also had a friend check it out and he says it looks like it might be an intake leak
Any tips on how to locate my problem a little easier?
Old Jun 5, 2011 | 02:26 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 350 Oil Leak Issue
The leak could be a valve cover, intake manifold, oil pan, rear main seal, front cover seal, front cover, oil filter, oil pressure sending switch......you get the idea.
Washing down the engine and then looking for signs of leakage might help. Leak check dye is a more positive way to locate the leak, but you'll need a pretty bright UV light source.
Example:
http://www.amazon.com/Tracer-Product.../dp/B000JFHNTM
Old Jun 5, 2011 | 05:34 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
My oil leak was from the oil pressure sending unit-it was cracked.
Old Jun 5, 2011 | 07:40 PM
82RedDemon's Avatar
ill definitely get the motor washed down, i think i'll check out the oil pressure sending unit first, this is the second time ive heard that mentioned as a problem, thanks for the input
Infested
May 22, 2018 11:56 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
