1988 trans am not starting
Old Jun 8, 2011 | 04:46 PM
Mihyar's Avatar
Car: 1988 Trans Am GTA
Transmission: 6 speed
Hey guy I have a 1988 trans am gta, it runs beautiful until one day it decided to not start, I changed a burnt fuse and it worked just fine for about a week then while I was driving it died as if I ran out of gas but it was almost a full tank. Till today it won't start but it cranks as if it wants to start. Any help guys I need it
Old Jun 8, 2011 | 07:51 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 1988 trans am not starting
security light on? getting spark? getting proper fuel? is the fuel pump even running? theres alot of holes with this and if it stays vauge you could be on a wild goose chase
turn the key on, does the fuel pump run? (whining noise)
check your fuel pressure at the schrader valve on the fuel rail, proper psi?
check for spark on no 1 cylinder
if your security light is lit your vats is being a PITA
and what fuse did you change????
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
stalkier
Aug 13, 2015 12:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
mizz0313
Aug 12, 2015 06:45 AM
stalkier
Aug 7, 2015 04:49 AM
