Timing once again
Old Jun 10, 2011 | 02:25 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Timing once again
The other day, my distrib in my 83 Carbed Z28 got bumped and the timing got messed up. I hit it with the gun yesterday and noticed that the timing mark is all over the place, ranging from 0-10* at times. Also, the idle is irradic. Yesterday, it was jumping from 500RPM to 1500RPM. Today, it is irradicaly loping a couple hundred from base idle of 700. This happens both under load and in park. I then revved and it sounded fine but as soon as it came back down, it started progressively missing worse and worse to the point where it sounded like less than 4 cyls were correctly firing. The final kick in the teeth was right before it stalled, the distrib started smoking. Should I find TDC again and time it from there? Or what could this be? The harmonic balancer lined up perfectly when I timed the car a month ago after my CFI to carb swap.
Old Jun 10, 2011 | 02:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing once again
You won't be able to set the timing well if it's not idling smoothly.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
