3 years sitting
Car: 1989 GTA
Axle/Gears: 3.23s
3 years sitting
Hi all, I have an 89' T/A 350TPI with a 6-speed conversion that has been sitting for 3 years and am now trying to fix her up and get her running again. Could I get some guidance as to where to start? The reason I parked it was because it started power surging while idling and would die and then refuse to start back up after a certain amount of time. It also would occasionally not turnover from a cold start despite a fully charged battery. The last code it threw was a code 42 and was told to check my O2 sensor and HEI the location of either I don't know. Thanks.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 3 years sitting
Code 42, as best as I can tell, would either be an issue with knock sensor, the electronic spark control module, or other ignition related components. Wouldn't have anything to do with o2.
Car: 1989 GTA
Axle/Gears: 3.23s
Re: 3 years sitting
It started, it's puffing out tons of blue smoke but it started god dammit. Now what do I do so I don't ruin it?
Justin92GTA
Aug 27, 2015 11:16 PM
