1983 CFI engine wont idle right!
Old Jun 11, 2011 | 11:58 AM
Rishardo17's Avatar
I just bought a 1983 Camaro with the 305 CFI engine last summer. This spring I put in a new cam, headers, and replaced the plugs, plug wires, distributor cap and rotor. In the process I removed the AIR pump and other emissions related equipment. The car runs, but it idles at 1500 RPMs for a minute, then the engine light comes and the RPMs drop way low and sometimes it will stall. Engine light goes off if I give some gas. I checked the codes its throwing, which are 33 and 34 (MAP sensor voltage high and MAP sensor voltage low). So I checked the MAP sensor with a vacuum pump and multimeter. It seems to be fine. I've checked for vacuum leaks with starting fluid with no luck. I'm stuck. Any ideas would be greatly appreciated.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
