Bad lifters
Old Jun 12, 2011 | 08:20 PM
ponchilaz's Avatar
Car: 1987 Camaro iroc z
Engine: 350 TPI 5.7L
Transmission: Automatic
Bad lifters
I have a bad lifter/lifters, do the lifters cause low oil pressure? also does it cause the engine to shake more then normal? would it be better off to go and get them replace or should i just change them my self? im stuck and dont know what to do anymore
Old Jun 12, 2011 | 11:50 PM
Guest
Guest
Posts: n/a
Re: Bad lifters
What makes you think it's the lifters? Being an '87, it should have roller lifters, and those last nearly forever.
Old Jun 13, 2011 | 04:48 PM
ponchilaz's Avatar
Re: Bad lifters
It is the lifters because i hear the bad lifter clicking in the engine in the back.
Old Jun 13, 2011 | 04:57 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Bad lifters
have you tried adjusting them ? a valve adjustment may cure your problem . new adjusting nuts may be in order , old ones have been known to back off . in any case , good luck .
Old Jun 13, 2011 | 05:27 PM
ponchilaz's Avatar
Re: Bad lifters
How do i adjust them?
Old Jun 13, 2011 | 08:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Bad lifters
Search "valve lash"
tyeo098
Nov 30, 2015 06:27 PM
RyanJB
Sep 14, 2015 03:39 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
