high pitched growling noise from engine bay(video)
Old Jun 13, 2011 | 06:32 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
after driving my GTA for 1000 mile trip, i noticed it started to make a growling noise coming from under the hood. it seems to me that it could be a pully or something. but i'm not sure. it varies with engine speed too. here's a vid.
Old Jun 13, 2011 | 06:33 PM
Twin_Turbo's Avatar
Re: high pitched growling noise from engine bay(video)
willing to bet it's the air pump
Old Jun 13, 2011 | 06:53 PM
Engine: 350 L98/LS2
what makes you say that? had that issue before or heard about it? or just a common problem?
Old Jun 13, 2011 | 08:06 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
It definitely sounds like a bearing. Check the alternator and the idler pulley.
Old Jun 22, 2011 | 08:25 PM
Engine: 350 L98/LS2
well it's the air pump pully making noise. would it be better just to remove the air pump and get a smaller belt? it's already been disconnected by a previous owner so it isn't doing anything being there.
Old Jun 22, 2011 | 10:47 PM
jtsk's Avatar
Depends on your local vehicle inspections. It is supposed to be there by law, but it they don't check....
Old Jun 23, 2011 | 12:27 AM
EvilCartman's Avatar
Car: '82 Z28
Take the belt off, start it up, noise gone? If it's gone, then start turning things by hand to see if you can find one that feels rough when turning. If the noise is still there with the belt off, you might have more serious issues or at least a little more involved repair.
Old Jun 23, 2011 | 06:05 PM
Engine: 350 L98/LS2
i already checked everything and found out it's my air pump. i was just asking what way was best, either to completely remove the pump and run a smaller belt, or buy an air pump delete pulley.
Old Jun 24, 2011 | 01:40 AM
Car: '82 Z28
doh...
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
