Distributor Question
Old Jun 14, 2011 | 06:46 PM
xsive79's Avatar
Car: 88 Formula
Engine: 5.7l 350
Haven't replaced a distributor before have couple of questions. These questions are probably gong to be really obvious.
First I picked up a MSD HEI Cap and Rotor Kit. When I got it back to my car I noticed that the one in there was the one with 9 terminals. The MSD only has 8 and it looks like the coil needs to go on top. Are these all universal or do I need to go back and get the 9 Terminal one?
Tips for replacing?
Old Jun 14, 2011 | 08:42 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Distributor Question
the cap & rotor kit you want is MSD# 8406 . installation is easy , remove old cap & rotor . do not remove plug wires (DO NOT) from old cap . install new rotor & cap . then remove 1 at a time wires from old cap and re-install on new cap in correct position . take great care that you do not mess up the sequence or wire position . good luck .
Old Jun 14, 2011 | 09:36 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
it seems like you got the cap& rotor for a coil in cap HEI. The one you need is the kind with 9 terminals,8 for plugs and 1 for the wire that goes to the external coil
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
