starting getting power but not enough to start
Old Jun 17, 2011 | 11:23 AM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
ok heres the deal when i turn the key i would say 50% of the time the sylenoid clicks sometimes once sometimes 5 times but it always start eventually. the battery is less than a year old the starter is less than a day old alt. is less than a year old. i hot wired the car to see if it was my igntion switch nope same thing happened. has anyone had this issue before is there a bad ground somewhere?
Old Jun 17, 2011 | 07:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: starting getting power but not enough to start
Check the connector to the neutral safety switch - mne did it and I found the connector was coming loose from the switch, drove me crazy for over 3 years until I finally figured it out.
http://www.austinthirdgen.org/index.php?pid=38
Old Jun 22, 2011 | 10:58 AM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
where is the switch located i looked at the diagram but physically on the car. and yours had the same symptoms im assuming?
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
