Exhaust Manifold is Overheating
Old Jun 22, 2011 | 04:17 PM
Rcaldw9's Avatar
Car: 1987 Red GTA Trans Am
I have an 87 GTA, 350. I finally got the car running really good yesterday and I've driven it about 4 or 5 times since then with it running that well. This morning I took it to walmart and it driven the same there but on the way back it has trouble advancing and when you push the gas the car barley goes somewhere until you let off and let it change gears. This has happened 3 times and everytime it happens, the exhaust manifold smokes on the drivers side. Does anyone have any idea at all? I know I need to change my oil soon.. would that make a difference? I'm just clueless and some help from ya'll would help a lot. Thanks
Old Jun 22, 2011 | 04:51 PM
Rcaldw9's Avatar
Re: Exhaust Manifold is Overheating
Oh and the Check Engine light came on when the Manifold stared heating up....
Twin_Turbo's Avatar
late ign timing
what code??
Old Jun 22, 2011 | 04:53 PM
Rcaldw9's Avatar
havent check the codes yet but I timed the car yesterday, adjusted the idle and changed the ignition coil
Old Jun 22, 2011 | 04:54 PM
Twin_Turbo's Avatar
how did you time it EST bypass disconnected (tan wire w. brown connector)???
Old Jun 22, 2011 | 04:55 PM
Rcaldw9's Avatar
yeah i disconnected it.. (The one on the passenger side by the firewall?)
Old Jun 22, 2011 | 05:06 PM
Twin_Turbo's Avatar
yes, near the blower motor. What did you set the timing at?
Old Jun 22, 2011 | 05:08 PM
Rcaldw9's Avatar
6*
Old Jun 22, 2011 | 05:11 PM
Rcaldw9's Avatar
I just had someone tell me it's my valve guide seals.. does this sound correct?
Old Jun 22, 2011 | 05:17 PM
Twin_Turbo's Avatar
no, that would not make the exhaust manifold smoke, the exhaust yes (esp. on startup)
Do you have an IR temp gun to measure the manifold temps L & R?
Old Jun 22, 2011 | 05:24 PM
Rcaldw9's Avatar
no i dont.. i just dont understand why it runs good all day then doesn't all of the sudden
Old Jun 22, 2011 | 05:32 PM
Twin_Turbo's Avatar
pull the code, that may be a good indicator.
Old Jun 22, 2011 | 05:41 PM
Rcaldw9's Avatar
Okay thanks.. I will later tonight.. Im not home yet
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
