engine makeover
Old Jun 25, 2011 | 11:48 AM
devin.jm's Avatar
engine makeover
Hello everyone! I just bought a 91 rs with the 3.1 v6. Yeah I know its not that beastly. Still fun though. Anyway, its been sitting for 4 years without any maintenance or driving. It has half a tannk of 4 year old gas and old oil. However, it cranks right up and runs like a scalded dog! I'm going to change the oil and oil filter, do a spark plug/wire change, and change the air filter to a k&n.
What should I do about the stale old gas? What else should I do under the hood? Should I sea foam it?
Old Jun 25, 2011 | 05:16 PM
devin.jm's Avatar
Re: engine makeover
and by the way, it has a new distributor if that means anything
Old Jun 25, 2011 | 05:23 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: engine makeover
id pull the conecter off the front of the fuel filter (so the gas isnt going through the fuel filter) then just jumper the pump and pump the gas out that way, fill it with good gas, change the fuel filter, put the chevron techron fuel injector cleaner in it and run most of the tank through then do the plugs and wires and what not and pray that the fuel pump doesnt die.
Old Jun 25, 2011 | 05:32 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: engine makeover
siphon/remove as much of the old gas as possible . (use it up in your lawnmower) oil change , fuel filter change , ck. tires for dry rot , a good cleaning & insp. of all hoses and belts . drive and learn more about your car . enjoy & good luck .
Old Jun 25, 2011 | 05:58 PM
devin.jm's Avatar
Re: engine makeover
well the previous owner ran fuel injector cleaner through it. killed the fuel pump. replaced it. that was about a month before i bought it. so ill probably just get rid of the gas and change the filter. sound good?
and what about sea foam?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
