oxygen sensor problem
Old Jul 6, 2011 | 03:36 PM
1roc89z28's Avatar
i have a 91 z28. ok well theres little space as is to get to this. so i rent the oxygen sensor tool.. and the o2 sensor comes right out. no problem. but i noticed that the one i bought is a little different(bosch) no problem. then when i try to put the new one i notice that it goes in but i cant torque it becouse of the stupid exhoust bolt thats connecting the exhoust manifold to the exhoust pipe.. ... the bolt is kinda long and it blocks the 02 sensor to fully going in..once im ready to torque it in i cant becouse it hits the bolt..i returned looked at another brand and its still being blocked...the only way i see it its to grind the bolt down.... but i dont have space to do any of this...sucks. anyone else have this problem or how to get around it
Old Jul 6, 2011 | 05:39 PM
torque_is_good's Avatar
Re: oxygen sensor problem
not to be a wise guy but headers solve that issue
Old Jul 6, 2011 | 05:48 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
yeah i was gonna suggest that..doesnt happen with mine...i just replaced my o2 with a Bosch unit
Old Jul 6, 2011 | 08:10 PM
1roc89z28's Avatar
u guys see the gay bolt... is there any other oxygen sensors i could get????
Old Jul 8, 2011 | 06:40 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Can you get a wrench down on it? Looks like from the top right of that picture you could get a wrench down on it. Or, can you back that bolt out on the exhaust to make room?
Old Jul 8, 2011 | 08:37 AM
Pocket's Avatar
Car: 91 Trans Am
Thats a stud and by the looks of it, fairly recently replaced so it shouldnt be totally frozen. Use the double nut method to back it down some
Old Jul 8, 2011 | 06:12 PM
1roc89z28's Avatar
whats the double nut method???
Old Jul 8, 2011 | 08:10 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Jam two nuts together, and turn it like a bolt. How about torching it off? Just hit it with a cutting torch so you can tighten down the sensor.
db057
Sep 4, 2015 07:57 AM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
beast94
Aug 20, 2015 06:44 AM
