camaro vs auddi
Old Jul 21, 2011 | 09:57 AM
  #101
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: camaro vs auddi
The 10 bolt will break in stock S10's. Doesnt change the fact that T5s generally cannot hold up to a 350. Some weak sauce 350s are fine, but any hot rod engine is gonna break it eventually.
Do a search, you'll find out the same thing. The GM T5 has a very weak case, under high torque it flexes and bends. Any kind of power shifting will kill it. Real torque will kill it. Aggresive shifting will kill it. A lot of guys here have been down that road and been disappointed.
Good thing about T5's is they're cheap. If you dont mind replacing a trans more often than you replace your clutch then the T5 is for you!
https://www.thirdgen.org/forums/tran...ate-today.html
Old Jul 21, 2011 | 10:41 AM
  #102
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Re: camaro vs auddi
Plenty of truth in that, but upgrading or replacing the 10 bolt is a MUST if you are pushing any kind of power. I will see how the T5 holds up with the new gears. I resisted going with the T56 because my car isn't even set up for a hydraulic clutch... The 82-83 cars just have a mechanical linkage. I also got bigger brakes from Stainless Steel Brakes because I was tired of smelling the stock ones haha.
Old Jul 21, 2011 | 11:14 AM
  #103
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: camaro vs auddi
To answer the question of what I had done to my car...
I had the suspension fully rebuilt with all the rubbers replaced with poly... New bearings all around, new springs and struts. Lower rear control arms, and UMI subframe connectors. Everything underneath the car that could fit in a sandblasting cabinet was sandblasted and painted.
Next I had the rear end rebuilt with the Eaton detroit locker rear dif and gears... T5 fully rebuilt and stronger gears installed, and PRO 5.0 shifter.
Engine freshen up (new 3" exhaust) crappy headers replaced with new ones, New poly engine mounts, downgraded from a racing clutch to a street clutch, MSD Pro Billet HEI distributor and had the intake manifold reinstalled. Higher volume Edelbrock fuel pump (My top end issues were due to my old pump barely putting out enough pressure and she was leaning out hard)
and a bunch of other little cosmetic crap...[/quote]
Is that all? Anything inpresive you had done?
Old Jul 21, 2011 | 11:55 AM
  #104
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: camaro vs auddi
Originally Posted by moneyz1
What do I have to put into my engine to allow my 84 z28 c.amaro to be able to beat any auddi or atleast keep up?
Any Audi is a little vague. We talking about an Audi R8? Aka the AWD 525hp V10 supercar? Or an Audi A3?
Drop a cammed 5.3L gen3 motor in your car and you'll be able to walk on alot of cars. There will still be faster cars but you'll be closer to beating 90% of the stock cars out there
350rwhp is easy with a cammed 5.3L LSx based engine.
Old Jul 21, 2011 | 12:09 PM
  #105
Car: 1992 Camaro RS
Re: camaro vs auddi
An S4 with a funny muffler. I asked the same question. look at my response on page 2 I think. Feel free to post anything of course I'm just saying letts not repeate anything.
Correction. It's page one
Dont listen to me. It's in the middle of page 2.
Old Jul 21, 2011 | 01:47 PM
  #106
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: camaro vs auddi
If you do anything to the rearend, put a girdle on it w/ stops, really helps stop the flexing, ring gear deflection, and bearing cap movement.....
Jegs part # 619-101-7.5G
Old Jul 21, 2011 | 02:08 PM
  #107
leeofstudness's Avatar
Re: camaro vs auddi
Hell if money isn't a problem why don't you just put a Rocket engine in the car.. no problems then. race him form here till cali. hahaha not sure about the rest of you. I have chevelles Cuda's Iroc.. they are all built for certain reasons....with any amount of money you can make them do what you want. b ut I don't build cars to beat the **** out of them.on the track or the street
Old Jul 21, 2011 | 02:15 PM
  #108
moneyz1's Avatar
Re: camaro vs auddi
What will I have to do to have the the 4th gen suspention fit in the 84 do it have to cut anthing?
Old Jul 21, 2011 | 02:48 PM
  #109
Re: camaro vs auddi
4th gen rear-ends are mostly a direct drop in. For disc to disc, and drum to drum its 100% bolt-in.
Drum to Disc and vice versa requires a proportioning valve change I believe.
Old Jul 21, 2011 | 03:16 PM
  #110
Car: 1992 Camaro RS
Re: camaro vs auddi
How to install a 4th gen rear in your 3rd gen.
https://www.thirdgen.org/forums/faq-...-gen-rear.html
Read this one first though. https://www.thirdgen.org/4thgenrear
Hope this helps man.
Old Jul 21, 2011 | 03:57 PM
  #111
Car: 1992 Camaro RS
Re: camaro vs auddi
Rear suspension is identical. Front suspension is completely different and you would need to build a whole new front half of the car to install it, for little to no real benefit beyond ride quality.
Old Jul 21, 2011 | 04:02 PM
  #112
Car: 1992 Camaro RS
Re: camaro vs auddi
The 4th gen will stick out the wheels 2" more on either side. it's not a problem and it's maks it look cooler
Old Jul 21, 2011 | 09:03 PM
  #113
Car: 1992 Camaro RS
Re: camaro vs auddi
If you like the look of your car wearing training wheels, then sure.
https://www.thirdgen.org/forums/post...374-post1.html
(note the first picture is with the stock rear)
On the other hand, you can get a similar, though MUCH MORE SUBTLE effect from using 4 front 16 inch wheels. The front wheels have an extra half inch or so of backspacing. The rear tires are a half inch out per side, somewhere around there.
This is what that looks like (My car)
Old Jul 21, 2011 | 09:36 PM
  #114
Car: 1992 Camaro RS
Re: camaro vs auddi
That looks sick. Why would you say it looks bad? Also, my wheels/rims aren't stock, their 17'/10". i think they'll look good with the 4th gen rear. But anyway, the 4thgen rear is just right for the 3rd gen if you want more power and a better launch.
and it's relitively easy to install. Plus you get disc brakes, and all the other added bonuses from having a newer rear end.
Old Jul 21, 2011 | 09:48 PM
  #115
moneyz1's Avatar
Re: camaro vs auddi
I like that hood but what u guys think of the iroc turbo hood?
Old Jul 21, 2011 | 09:50 PM
  #116
Car: 1992 Camaro RS
Re: camaro vs auddi
Just because it looks so agressive, i'd go with either the cowl induction, or the stinger scoop syle hood.
Old Jul 21, 2011 | 10:20 PM
  #117
Car: 1992 Camaro RS
Re: camaro vs auddi
If they're the correct backspacing for a fourthgen rear they'll look just fine.
They're exactly the same internally. An 89-92 10-bolt's internals are all completely interchangable. The only difference is the 93-97 axles are longer and their disc brake calipers look a little different. 98-02 axles are slightly narrower, but not by very much. The gears and carriers are all completely interchangable. Earlier 10-bolts are exactly the same except there are a few less splines on the axles. Gonig to a 4th gen 10-bolt will not give you more power or a better launch. Gears may give you a better launch, but it depends.
and it's relitively easy to install. Plus you get disc brakes, and all the other added bonuses from having a newer rear end.[/QUOTE]
Old Jul 21, 2011 | 10:30 PM
  #118
moneyz1's Avatar
Re: camaro vs auddi
A lot of Those hoods say they don't work with out an air box and they say air box is tpi cars only so that means my 84 wont be functional will the hood won't when its on the car right
Old Jul 21, 2011 | 11:23 PM
  #119
Car: 1992 Camaro RS
Re: camaro vs auddi
Are you guys joking?
Old Jul 22, 2011 | 12:04 AM
  #120
affliction1's Avatar
Car: 89 chevy camaro rs
Re: camaro vs auddi
not sure like i said there my plans still have to do write up but in my head its perfect
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
