What is this piece?
Old Jul 10, 2011 | 10:56 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
What is this piece?
This metal piece was just laying in the box with my new harmonic balancer. The balancer was sealed in a bag. Is this supposed to slide into the alignment grove? It does fit the grove. The old one did not have anything like this either?
Old Jul 10, 2011 | 11:04 AM
Re: What is this piece?
Yes that goes into the groove. It holds the balancer in place, rotationally.
When you see people complain about "my timing marks don't line up", there's always the possibility that it's because that is missing and the damper is just jammed on randomly instead of in its correct orientation on the crank.
Its official name is "woodruff key".
Old Jul 10, 2011 | 11:07 AM
Robby12's Avatar
That is a woodruff key more commonly referred to as a key way,it pushes in to the slot on the crank then you line up the key way on the crank with the one balancer i put a block of wood on the balancer and hit the wood to press the balancer on they do make a tool to do it but you may not have it
Old Jul 10, 2011 | 11:13 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
So this would go onto the crank slot before sliding the balancer on?
Old Jul 10, 2011 | 11:31 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yep, is there not one there already? Even if there is, tap it out and replace with the new one.
Old Jul 10, 2011 | 03:31 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Any advice on how to get the old key out? Tried pliers and vice grips and they just slip off because there isn't much to grab. The thing is getting chewed. There is no edge to pry with a screwdriver. Now it'll prob not be good to reuse.
Old Jul 10, 2011 | 04:23 PM
Chisel; from the front
Comes RIGHT out
Old Jul 10, 2011 | 04:29 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Comes RIGHT out
Tried after my last post. Didn't budge, but pieces started coming off. Giving up for today, I'll beat the **** out of it another day.
Old Jul 10, 2011 | 04:36 PM
That's cool; just don't damage the crank. The new key needs to fit in it tight.
Old Jul 10, 2011 | 05:00 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Thanks, I do know to be careful of the crankshaft. Who would of thought the key would be so much more trouble than the balancer.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
LC2 TECH
Oct 13, 2015 11:53 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
RS Reaper
Sep 27, 2015 07:04 PM
