1992 TPI Camaro 305 to 350
Old Jul 13, 2011 | 03:04 PM
FLAcamaro1's Avatar
Car: 1992 camaro Z28
Transmission: 700r-4
Axle/Gears: 308
Hi Guys, Hope someone out there can help me out. Bought a 92 z28 heritage addition . Guy said motor ran good but after i bought it it started rapping. Upon disassembly i found 3 of the rods had no bearings. So I though I might as well go 350 or L-98. I want to keep the tpi set up and bought a 1990 vette long block with the aluminum heads. Questions i have are.... Can I use the 6 qt oil pan from the vette? will it fit? also how much can i modify the L-98 and not have problems with the computer. Thanks Dave
Old Jul 13, 2011 | 06:22 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Re: 1992 TPI Camaro 305 to 350
Well for one you will need to mod the comp starting out, gotta get yourself a 350 prom. Other things you will need are 350 injectors and a knock sensor for a 350. I have no idea about the oil pan sorry. If you are going to get a prom, I highly recommending burning your own, or getting someone who knows how to do it, if you do this you can mod the engine as much as your heart desires.
Old Jul 14, 2011 | 02:11 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
the oil pan off your 305 will work
Old Jul 14, 2011 | 04:09 PM
FLAcamaro1's Avatar
Axle/Gears: 308
the 305 oil pan was really banged up. i have the corvette 6 qt pan but dont know it will clear the crossmember. Thanks
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
