305 heads on a 355 w/ flat tops...long term problems?
Old Jul 20, 2011 | 01:51 PM
thafaz's Avatar
Car: 86 IROC
Engine: 355
Transmission: WC 5spd
Axle/Gears: 3.24
Gents,
I finally got my car together.....details in my signature.
Runs great....scares me enough that I only matted it once. First tank through was 28 mpg...took a month and a half of weekend and evening driving to get though it.
It was hot last week and I took it out; filled it up and was coming back. I decided to lean on it in 4th gear....started to ping!!! Not good!!! I dropped a gear, hit it, no problems.
I asked my mechanic buddy about this....he looked into it and says my compression is too high..14102187 58cc heads w/ flat tops works out to 10.5 - 11 compression. That, combined with premium from Mr. Gas (probably not the 94 octane I first filled with) and the weather (38C) resulted in the pinging.
Are there any long term affects on the short block due to high compression? I like the way it runs, but don't want to grenade it.
Faz
Old Jul 20, 2011 | 01:58 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 305 heads on a 355 w/ flat tops...long term problems?
You'll blow apart pistons, especially hypereutectics like the KBs, and the engine may still run but you'll lose huge amounts of compression on each piston that crumbles. There will come a point, sooner or later, where the damage is bad enough it wont run at all.
http://www.google.com/search?client=...N&hl=en&tab=wi
Why did you stay with the swirl ports?
Old Jul 20, 2011 | 02:09 PM
thafaz's Avatar
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
Got the heads from ebay a while ago, they came with 1.9/1.6 valves installed....chose the cam (260h) to match and to limit the power to keep the 5 speed alive. When I started building the engine, I realized the rings were loose...sent it in for a rebuild. They installed flattops......oops!!!!! If I had to so it again (and it looks like I will), I would have bought an Edelbrock power pack and been done with it.....
Old Jul 20, 2011 | 02:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Did they deck the shortblock? know what the quench is?
With 58cc heads, and flat tops --- and your short cam - that is a lot of compression.
You can pull some timing for now, don't ever lug it around, etc. Keep it full of high octane fuel (94 if you can find it).
The ideal situation is to simply swap heads. Vortecs with a vortec carb intake would work well, or aftermarket 64cc heads would also work.
Old Jul 20, 2011 | 03:09 PM
thafaz's Avatar
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
I think 64 cc heads will be the way to go.....they've come down in price substantially since I bought the last set.
Much thanx for the input.
Faz
Old Jul 21, 2011 | 04:17 AM
Car: 1992 Camaro RS
Theres a lot more to head choice than chamber size and valve size.
Get a decent casting. If you want stock heads, get 906, 062, 113, or 083. There may be others but the ones I listed are fairly common. 906/062 are Vortec. Any other number IS NOT VORTEC. You'll need a new intake to fit them.
Old Jul 21, 2011 | 09:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A mild cam and high compression is a recipe for detonation.
Those really are rotten heads. Sorry to hear you paid real money for them.
As stated, larger chamber heads that flow better are in order. This head/manifold kit would wake up your engine and eliminate the detonation problem:
http://sdparts.com/details/scoggin-d...ter/sd8060akit
Old Jul 22, 2011 | 08:35 AM
thafaz's Avatar
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
Hi 5/7,
Could you recommend a set of aluminum heads that would bolt on without replacing the intake?
Faz
Old Jul 22, 2011 | 09:26 AM
Sonix's Avatar
Car: 1982 Trans-Am
Summit makes an inexpensive set of aluminum heads. 64cc chambers, ~200cc intake ports IIRC. I think they are ~$800 assembled for the pair. I remember thinking they were a screaming deal.
I would point to those as the best bang for the buck, personally.
Old Jul 22, 2011 | 10:00 AM
thafaz's Avatar
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
Hey Sonix,
They've gone up....
http://www.summitracing.com/parts/SUM-162111/
The bummer with Vortecs is the expensive intake replacement.....for $1200, I'm only getting $700 in performance increase....I figured $800 would get me aluminum that would at least be lighter. Then again, might end up right back where I am now....mismatched combo.
What about these?
http://www.jegs.com/i/Patriot-Perfor...ductId=1250658
Faz
Old Jul 22, 2011 | 12:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Or of course you can look on this forum for people selling used aluminum heads, factory or aftermarket, your local classifieds, or racingjunk.com or other sites like that.
ie;
https://www.thirdgen.org/forums/engi...der-heads.html
Those patriots look like they'd do the trick too.
Fanatic1074
Oct 3, 2022 05:57 AM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
