Best heads
Old Jul 22, 2011 | 08:13 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Best heads
I am going to go with a Stealth-Ram set up with my Paxton, looking to add heads and a cam, any thoughts on bang for the buck. It is a 305 TPI now with the Paxton, being it is a 91 Z convertible I want to keep the original motor (has 88,000 miles) I know I could drop a 350 in but i want to keep the original motor.
I was going to do the Vortech heads and a Edelbrock Vortech TPI base but that dam manifold is $600-700
Old Jul 22, 2011 | 08:32 PM
Guest
Guest
Posts: n/a
Re: Best heads
Why not a Vortec version of the Stealth Ram?
Then do 1.6" exhaust valves in the Vortec heads, especially since you're forcing extra intake flow.
Old Jul 22, 2011 | 09:43 PM
91 Droptop's Avatar
Re: Best heads
I did not see that it had a Vortech version, with vortech stealth-ram and aluminum heads and a better cam I should hit about 325hp correct? with my Paxton being redone and the new impellar they are rating it at an additional 120hp on top of the motor. With the 700R4 I will be happy if I get about 360 or so to the rear wheels.
I am starting on the body this weekend, need to patch the firewall and the floors, then the entire body. I hope to have this back on the road by mid October.
Old Jul 27, 2011 | 10:39 PM
GOTCHEVY's Avatar
Car: 97 Z28
Engine: 396 LT1 518whp All Motor
Transmission: 6spd
Axle/Gears: 4.10 LSD
Re: Best heads
I have some vortecs for sale $350
Old Jul 27, 2011 | 10:58 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Best heads
If you do heads/cam/supercharger along with supporting mods you should blow 325rwhp out of the water. You should be closer to 380rwhp.
N/A LT1s with a LT4 hot-cam regularly hit 330rwhp and they have head flow similar to a vortec head, and the HSR has similar flow and power curves.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
