Timing mark way off...
Old Jul 23, 2011 | 01:45 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I purchased this replacement balancer, http://www.summitracing.com/parts/RN...e%7c5.0L%2f305
Before replacing, I checked base timing (unplugging esc) and it was at 0* where it should have been. Old balancer grove lined up with 0* mark on tab. Left timing as is. I made sure the grove on the new balancer was positioned the same as the old, it was. And the keyway for the balancer is there in the crank and the balancer does not feel like it moves out of place. Now after passing emissions I was going to set timing 4 or 6* advanced. The mark on the balancer is no where close to the timing tab. The mark on balancer is rotated towards the power steering pump(drivers side), like it is super retarded. My timing light was attached to the #1 plug. What would throw this off so much? Seems like I will have to time by ear.
Old Jul 23, 2011 | 02:44 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Timing mark way off...
I ran into this same problem a while back. It turned out that I was looking at the balancer wrong when comparing everything. At some point, Chevy decided to switch to timing from the top vs. timing from the side using the old timing tab. I had a tab, but couldn't get the thing to time to save my life (305 V8). I ended up buying a balancer made by Professional Products that had the standard timing marks from 0 to 60 degrees as well as marks for timing from the top. Problem solved. I am guessing the new balancer you have was designed to time from the top. The part number for the PP balancer is 80000. Hope that helps.
Old Jul 23, 2011 | 02:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can remark your balancer, put on a different tab, put on an aftermarket cover, or replace the balancer.
Old Jul 23, 2011 | 03:00 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
My timing tab is on top. Always was timed from the top.
Old Jul 23, 2011 | 03:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but your balancer is timed from the side.
Old Jul 23, 2011 | 03:16 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
It is set up as the original which was timed from top. I am just wondering how identical parts would time in diff locations.
Old Jul 23, 2011 | 03:27 PM
jtsk's Avatar
Perhaps they sent you the wrong part by mistake???
Old Jul 23, 2011 | 03:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You stacked the two balancers, aligned the keyways, and the TDC marks are in exactly the same position?
Old Jul 23, 2011 | 03:57 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Yes and been running fine as normal, I wanted to adjust timing today and ran into this. New balancer has been on a few weeks. If timing had been thrown I would notice.
Old Jul 23, 2011 | 04:04 PM
jtsk's Avatar
Have you tried another timing light to see if you have the same issue?
Old Jul 23, 2011 | 04:13 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Inductive , adj. timing lights are known to be inaccurate sometimes, get a hold of an old school light w/ the spring thingy on it to clip to the plug and wire and check it. When using inductive timing lights, make sure the #1 wire is isolated along w/ the inductive clamp from the other wires. I have seen this problem before, even w/ a good light....
Old Jul 23, 2011 | 04:42 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
My light is a basic inductive with no adjustments.
Old Jul 23, 2011 | 04:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, I didn't see that you'd had it running already, I thought this was freshly installed. Pull the balancer off and check where the TDC mark is in relation to the keyway.
Old Jul 24, 2011 | 08:22 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I manually got engine to tdc and the mark on the balancer was lined directly with 0° on the tab. The rotor was pointing at the #1 plug wire also. Maybe my light is on the fritz.
Old Jul 24, 2011 | 08:29 AM
J91's Avatar
J91
If you use the inductive light try isolating the clip as far as you can from any other spark wires or any other type of wire, they pickup electric fields all around them.....
midge54
Dec 27, 2019 04:14 PM
Camarothatcould
Aug 20, 2015 08:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
