need help with 89 GTA 350 TPI
Old Jul 20, 2011 | 07:38 PM
Mwbrowning's Avatar
Car: 1989 Trans Am GTA
The car was working fine, I stopped and went inside somewhere and it would not start up and keep running any more. It will crank over and start and die imedietly. I have changed the Fuel filter, and Fuel Pump.I get 42 PSi on the fuel rail. I have bypassed the VATS system in the past. I can spray fuel into the intake and the car will run, as soon as i stop spraying the fuel, it dies. I have also replaced most of the fuel injectors in the past. If you have any ideas about what could be happening please let me know.
Old Jul 20, 2011 | 10:31 PM
Mwbrowning's Avatar
Re: need help with 89 GTA 350 TPI
Hey guys. Any help on this would be helpful. I am at a loss as to what is going on with this car. Any and all help would nice. If i need to put more information just let me know.
Old Jul 21, 2011 | 01:12 AM
affliction1's Avatar
Car: 89 chevy camaro rs
check/clean iac or maf
Old Jul 21, 2011 | 01:24 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
possibly ^^
is it throwing any codes? whats the SES light doing when you turn the ignition on before you start it?
Old Jul 21, 2011 | 09:32 AM
Mwbrowning's Avatar
I have swapped out the maf already but i can try again. I will have to try cleaning the iac. The SES light comes on when i turn the key tot he On position but then goes off. I have had problems with the VATS in the past and had to bypass the system with resistors. If you have any other ideas keep them coming. i need all the help i can get on this car.
Old Jul 21, 2011 | 10:00 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
You said you have replaced some injectors but not all? Check the injectors and see if you have any bad ones. I had a similar issues and it was bad injectors.
Old Jul 23, 2011 | 09:49 PM
Mwbrowning's Avatar
this is what solved my problem. Thank you. I checked the injectors today and the only three that i did not replace 6 months ago where the ones that went bad. After replacing them the car will start and run smooth. thanks again.
Old Jul 24, 2011 | 03:12 AM
rdhanded2's Avatar
Top Answer: 1
Glad to hear it is fixed!
Old Jul 24, 2011 | 12:20 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
nice
gta90
Sep 15, 2015 04:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
