engine build!
Old Jul 25, 2011 | 01:42 AM
Fallenrival38's Avatar
Car: 91 Firebird formula
Engine: TPI 305
engine build!
I've got a 91 firebird formula TPI 5.0 .Im starting to build a street/strip engine for it. I have "rebuilt" many sbc engines,but this is the first "performance" engine I have a goal for. im looking to have at least 400hp at the wheel. i have a 350 4 bolt main block out of a early 90's blazer. Can someone please help me with a list of parts i will need. reviews on parts would be alot of help also.
trans-700r4
rear end- 7.5 now, will be replacing with 9in ford (373 gear)
Old Jul 25, 2011 | 01:46 AM
Blazer79's Avatar
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
Re: engine build!
I'd say start comparing cylinder heads and go from there. It all depends on your budget too. A 383 rotating assembly is a good start too. And they are affordable now compared to a few years ago.
Old Jul 25, 2011 | 09:24 PM
Engine: TPI 305
Re: engine build!
thank for the reply. I have been thinking of a 383 " 6in rods of course". I have a set of stock vortec head i took off of a Z71, and my friends a ***** ,but his dad is a machinist and loves sbc engines, pretty sure he would help me out on all the machine work, to put 2.02 intakes and 1.60 exhaust valve. I have also been thinking about doing the work to my 305 TPI heads just for the simple fact that the combustion chamber is smaller compared to the vortec's.
Old Jul 27, 2011 | 01:04 PM
Notalent's Avatar
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
Re: engine build!
trans-700r4
Did you plan on running a carburetor or your TPI? Do you have a budget? 400HP @ the wheel is roughly 500HP at the crank....for a sbc chevy this is not a very streetable engine and will not produce vacuum needed for power accesories, but can be done with extra modifications. To get that power your going to need compression, good 190-200cc runner heads, a big cam and a good induction system. Cubic inches is going to be your friend here as well.... 383 stroker is the way to go.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
