Recommendations for timing chain and gear
Old Jul 26, 2011 | 02:10 PM
Tidan's Avatar
Looking for a good timing gear set for my '85 T/A with a chevy 350. Putting in a Lunati bracket master II (00017) cam and Edelbrock 2701 performer intake.
Any tips would be greatly appreciated! Thanks!
Old Jul 31, 2011 | 12:36 AM
diehard92's Avatar
Car: 90 Iroc-z tune port 350 mod
Engine: TPI 350 chipedout neck breaker tran
Transmission: 700R4 built
Axle/Gears: 7.5 10 bolt rear end
Re: Recommendations for timing chain and gear
man i just tried to put a double roller timing chain in mine and all i got was a loud bang out the back tail pipes you mit want to check the spec before jumpin gin to this bro i had to go throw 5 differernt ones till the parts house got me a replacement one
Old Jul 31, 2011 | 08:05 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Just get a good double roller, and you'll be happy. I have one that I've ran for years with no issues.
Old Jul 31, 2011 | 05:18 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
I used a Comp Cams double roller set and have had no issues at all.
Old Jul 31, 2011 | 06:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Every manufacturer has different quality sets. I use a good double roller Cloyes in my engine. It also uses a torrington bearing to ride against the block.
The advantage of an OEM chain is long life and quiet operation. The aftermarket roller/double rollers versions come in different qualities. The cheaper ones will tend to wear out after a few years of daily use. A true roller is a better quality.
Drilling very small holes in the oil gallery plugs behind the chain will help keep it better lubricated.
Old Jul 31, 2011 | 07:27 PM
Tidan's Avatar
Awesome, thanks!
I went with the Cloyes double roller...something like 30 bucks from summit. I hope it works!
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
