Dumb Dimmer rod frustration!
Old Jul 26, 2011 | 02:18 PM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
ok, after alot of research about the dimmer, i found my switch and rod still good working order, BUT the rod up on the steering column side is not hooked up and the plastic cover is dangling(not broke) from the tilt lever.
i can change brights and dims by pushing the rod with my finger right under the S. wheel, but its silly to do.
It is so frustrating that I can't figure out how this rod goes on the plastic thing on the steering wheel side?!?! its like a dumb trick toy you'd find at cracker barrel! I might need to see a picture of one hooked up correctly, I'm to dumb to figure this out!
PLEASE HELP?!
-Shane
Old Jul 26, 2011 | 08:11 PM
torque_is_good's Avatar
Re: Dumb Dimmer rod frustration!
here is how I fixed mine
https://www.thirdgen.org/forums/elec...ch-repair.html
Old Jul 26, 2011 | 09:44 PM
89shane350's Avatar
Originally Posted by torque_is_good
Yah, I have a new one from a 79 z/28 already and ready to go, but it's my last option, I want one last chance at keeping it stock, thanks for that though.
Anyone else want to take a crack at it?
PS which wires are they? Green, Yellow, and Tan I think? and what one goes where incase I go this route?
Old Jul 26, 2011 | 10:38 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
There should be a small plastic doohickey that transmits the motion from the combination switch to the dimmer rod:
https://pontiworld.com.au/usgmsp/pro...oducts_id=5425
Sounds like that is missing - not sure but from memory if you can reach the dimmer rod with your finger, it's probably not there. Maybe that's why the outer side cover is off, removed by the po to get to the rod?
Old Jul 26, 2011 | 10:43 PM
89shane350's Avatar
i see, i thought the rod connected to the inside of the cover, no wonder it doesn't work,
hopefully this is it! very helpful kind Sir.
Old Jul 26, 2011 | 10:56 PM
89shane350's Avatar
part number
ACDELCO D844 if anyone else goes through this hell!
Old Jul 27, 2011 | 05:17 AM
Originally Posted by 89shane350
part number
I had all of those pieces and mine was still erratic. That is why I went with the floor mount; enough was enough.
And yes, I tried moving the switch a little. I've had the car completely torn down, and I mean completely so I wasn't going to lose sleep over going the floor mount switch. I need the switch to always work and thus why I went the floor route.
Old Jul 27, 2011 | 09:49 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Heh - now you just gotta get one, and pull your column apart to install it - fun fun! Mine was missing too, and I went this route.
Or just go floor switch like torque said, much easier if you're not worried about original function.
Old Jul 27, 2011 | 07:34 PM
89shane350's Avatar
Well i ordered it for $5(last one from rockauto!) and its been shipped, it better work! if not i got the floor dimmer wired up and ready to splice into my car.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
