Timing chain sounds
Old Jul 26, 2011 | 09:11 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Timing chain sounds
I own a 88 camaro base with LO3 v8 I recently purchased it in april of this year and it sat for two years before i bought it. At around 750 rpms theres a really noticeable almost rattling sound coming fom what i beleive is the timing chain. has anyone else had this problem before? So far it has not affected performance or anything but it is really annoying thanks.
Old Jul 26, 2011 | 10:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Timing chain sounds
Is it coming from the timing chain cover area? Its always possible for one of the cam bolts to back off if the cam was changed. It could also be a severe slop issue in the chain. Id pull the timing chain cover and have a look. Be aware that you have to drop the front of the oil pan slightly to get the TC cover back on, which can be a pain in itself.
Old Jul 26, 2011 | 10:06 PM
Car: 88 Camaro SC
Engine: SFI'd 350
You may also want to double check and make sure its not an accessory like the smog pump, water pump, belt tensioner, etc. All of which can make noises that will sound like theyre coming from that area of the engine.
Old Jul 26, 2011 | 10:38 PM
Engine: 305 LO3
thanks for the info
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
