Car horn help
Old Jul 27, 2011 | 12:32 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Car horn help
Hey guys, I have to get my camaro inspected in a month, and one of the things I need to fix before then is my horn, it doesn't work, I'm not sure which fuse in the fuse box it is so I haven't been able to check if it's just a blown fuse but can you guys help me out with this?
Old Jul 27, 2011 | 01:24 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Car horn help
The same fuse is for the dome light, lighter, power mirrors, power locks and third brake light. If they work it's not the fuse. On airbag cars, sometimes gradual warping of the airbag cover from heat makes it difficult to press hard enough to actuate the two plastic horn buttons behind the wheel, or the buttons break. You should probably take off the air bag and have a look if it's not a fuse problem
Old Jul 27, 2011 | 10:54 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Car horn help
Thanks man, I'll try that
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
