oil leak from oil filter, excessive pressure?
Old Jul 28, 2011 | 07:48 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
just got my motor ready to start for the first time, but i have a big problem. from cranking the motor over i noticed that i had oil leaking form the oilfilter. further investigation lead me to belive it was a bad oilfitler i replace the K&N oilfiter with a STP filter yet have the same problem. i thought it was the oil pressure relief valve in the oilpump, so i removed the oilpump and took it a part. the valve moved fine and the spring was seated properly, as i would expect as it was new. I need suggestions for this problem asap. so any input would be greatly apreciated.
Old Jul 29, 2011 | 01:42 PM
torque_is_good's Avatar
Re: oil leak from oil filter, excessive pressure?
are you sure it's from the oil filter and not the oil pressure sending unit?
Old Jul 29, 2011 | 07:08 PM
Engine: 350TPI/ S50
yes i'm very sure that the location of the leak is the oilfilter.
Old Jul 29, 2011 | 07:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Check to see if an old filter gasket is stuck on the oil filter mount. Double gaskets will leak like that.
Old Jul 29, 2011 | 08:15 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have had this happen to me. The old gasket is stuck, but it is hard to see.
Old Jul 29, 2011 | 10:29 PM
Engine: 350TPI/ S50
there is no old gasket its a brand new motor, i put it together my self.
Old Jul 29, 2011 | 10:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Please don't be offended, the only 2 things I can think of --
A crack in the block casting
The 2 bolts holding the oil filter spin-on adapter may be loose.
Old Jul 30, 2011 | 02:20 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Some of the oil filters have an extra thick sealing ring. Ive had these leak as well with high pressure oil pumps. I have a standard volume melling with a high pressure spring that has 70 PSI at all times. The mobil-1 filter was the one I had issues with. It would just spew oil when installed normally. If I cranked it way down, it would stem most of it, but still leak a little. Some companies like purolator use a thinner sealing ring. If everything else looks ok, try one of the pure-ones or a similar filter with a thin sealing ring and see if it still leaks.
Old Jul 30, 2011 | 02:45 AM
Al Weyman's Avatar
Car: 87 Iroc Race car, 71 Z/28 Race car
Engine: 5700cc self built
Transmission: Muncie 4 speeds
Axle/Gears: 3.75/3.5
When I fire my race engine up it has nearly 100psi pressure on 5/40 fully synthetic if it had 20/50 in it then it may well leak, I let it warm gradually before getting jizzy on the throttle to save oil filter blow out because I have locked out the oil filter bypass valve as its only really required if you are lazy and dont change your oil filter as often as you should or for starting on cold mornings with thick oil and has no place on a race only car and wonder if you have done this as to sit warming the engine for 5 minutes or so wouldnt be practical on a street driven car but for a pure race car is not a problem.
Old Aug 1, 2011 | 01:30 PM
Engine: 350TPI/ S50
would never be offended i asked for ideas. but i had the block magnafluxed before and the two bolts where properly tightend.
Old Aug 1, 2011 | 01:35 PM
Engine: 350TPI/ S50
i have a standard volume/pressure mellings pump. i had a k&n filter at first, it was tightend down normally but when i went to take it back of it was super tight. the second filter was a mobil one. i'll try a pure-one filter when i put the pump back in. my machinist said that the oil pump's relief valve could have been stuck from sitting. so i hope it works after taking it apart.
Old Aug 1, 2011 | 01:40 PM
Engine: 350TPI/ S50
sorry ur post is a little hard to read, but i get the jist of it. i never started the motor yet, if i had it proly would have burst the filter. your comments don't really apply to me seeing as its a street motor running 10w30 and the standard pump shouldn't produce more than 50 psi. thanks for ur input.
Old Aug 1, 2011 | 01:52 PM
Al Weyman's Avatar
I'm english sorry lol! Have you blocked out the oil filter bypass valve? As I am sure you are aware its in the little alloy block that holds on the filter not in the oil pump thats the pressure release valve.
Old Aug 1, 2011 | 02:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have had a motor that the oil filter adapter was cracked in half.
When I took the filter off everything looked fine, put it back 2gether Started it up and it would leak oil ! I finally took the adapter off and found it was broke in 2 pieces! Replaced the adapter and all was fine in the world.
Old Aug 1, 2011 | 02:14 PM
Al Weyman's Avatar
Yep good point its only a silly bit of alloy casting and and over tightening the filter or running an oil cooler takeoff can easy strain it.
Old Aug 4, 2011 | 02:18 PM
Engine: 350TPI/ S50
WELL I GOT THE OILPAN BACK ON, I EVEN THREW A DIFFERENT ADAPTER ON IT, CRANKED THE MOTOR FOR A WHILE YESTERDAY NO OIL LEAKES. STARTED IT TO DAY THE OIL FILTER BURST SO NOTHING I DID FIXED MY PROBLEM. ANY MORE IDEAS?
Old Aug 4, 2011 | 02:22 PM
Al Weyman's Avatar
Well surely it can only be the pressure release valve in the oil pump and/or the oil filter bypass valve. If the pump is generating too much pressure and you have blocked the filter bypass valve then this could happen which is why I am carefull when I start my car up cold.
Old Aug 25, 2011 | 01:51 PM
Engine: 350TPI/ S50
after haveing to tear half the motor back a part i fixed the probelm. now its all back to gether and i cant get it started. its in time and has spark and fuel pressure. it seems to me that the injectors are not opening and ideas why?
Old Aug 25, 2011 | 05:03 PM
Al Weyman's Avatar
So what was the oil pressure problem?
Old Aug 26, 2011 | 09:24 AM
Engine: 350TPI/ S50
I had two issues with that problem. the first being a missing oil plug under the head. and the second problem was that the machine shop drove a second plug under the main cap with out removeing the old plug. I'm not sure who droped the ball on that but the machine shop was supposed to remove and replace all the plugs when it was sent to be boiled.
Old Aug 26, 2011 | 10:07 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
are you getting oil to the top of the motor pressure is resistance to flow so something in the block could be blocking the oil and it has nowhere to go and the filter is first to give and the relief in the pump for not giving in
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
