Engine changed?
Old Aug 1, 2011 | 07:05 AM
crazyeight's Avatar
Car: Pontiac Firebird 1987
Engine: 305 4bbl
Engine changed?
Hi everyone
Recently ive been told that my engine in my firebird 1987 is not the original one. It should be a v8 305 4bbl i think.
How can i check what engine i have?
I know there should be a number on the back of the engine on the right side when you stand in front of the car but its impossible to see.
Any other suggestions?
If you guys need any photos just tell me and i will fix it.
Excuse my bad english and i hope you understand
Old Aug 1, 2011 | 09:13 AM
Notalent's Avatar
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
Re: Engine changed?
Whats the 8th digit of the vin #? This will tell you what engine you should have in it.
Vin H = Carbed
Vin F = TPI W/ Roller Cam
Vin 8 = 350 TPI
If you want to see what you have in there now, grab the casting numbers off the rear of the block and pull the valve cover to get a head casting number and we can cross it over for you.
Old Aug 1, 2011 | 09:28 AM
Guest
Guest
Posts: n/a
Re: Engine changed?
Impossible? No. You do need a flashlight, you do need to move the wiring harness out of the way, and you may need some rags to wipe away any grime that might be there.
Old Aug 1, 2011 | 11:46 AM
crazyeight's Avatar
Engine: 305 4bbl
Re: Engine changed?
Its a Vin H
Will try tomorrow if i can find that number
Thx for the help for now
Old Aug 1, 2011 | 12:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Engine changed?
If the block hasn't been decked, you can pull the codes off the pad in front of the passenger side head. That can tell you what the engine came from.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
