Requirements for zz4 cam swap
Old Aug 1, 2011 | 01:37 PM
247Lane's Avatar
Car: '89 GTA
I have a zz4 cam i want to install into my l98 with iron heads. I'm wondering what valve springs and what else I am going to need. I don't want to do any machining to the heads and I don't want to spend too much. Will the LT4 hotcam springs fit? I was thinking about these http://paceperformance.com/i-6255251...-diameter.html
Old Aug 1, 2011 | 03:28 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Requirements for zz4 cam swap
http://paceperformance.com/i-5146515...-525-lift.html
i think your better off buying this since u gonna need the retainers keepers also
Old Aug 1, 2011 | 03:50 PM
Guest
Guest
Posts: n/a
To do it without cutting the guide bosses, you definitely need offset locks, +0.050", or beehive springs to clear that 0.510" exhaust lift. Maybe both?
You also need to check if your rocker slots are long enough.
Old Aug 1, 2011 | 04:44 PM
247Lane's Avatar
Car: '89 GTA
Thanks SiCkRs and ronnjonn! Will I need to replace my rockers, or can I keep the stock rockers?
Old Aug 1, 2011 | 05:40 PM
87350IROC's Avatar
Car: 87' IROC
You will need to run screw in studs. I pulled several press in studs out with the ZZ4 cam.
lt500r55
Sep 1, 2021 01:30 PM
junkcltr
Aug 2, 2019 11:12 PM
Cameeeero
Sep 18, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
