will my engine take 200 shot
Old Aug 3, 2011 | 01:13 AM
11seccamaro's Avatar
Car: 82 z28
Engine: 60 over 350
Transmission: 4 speed standard
Axle/Gears: moser 9 inch 411
Hi i have 82 camaro full cage subframe connected ford 9 inch 410 gears
built turbo 350 with 4000 stall.
The engine is a solid roller 383
570 lift
vic jr heads and intake with roller rockers
balanced
forged 10.5 to 1 pistons
steel crank
h beam rods
arp head and main bolts
850 holley
4 bolt main
Racing this weekend and debating uping my nitrous from 150 to 200 shot do u think my engine would safely take it?
Thanks.
Old Aug 3, 2011 | 09:53 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: will my engine take 200 shot
if you change the timing appropriately and make sure you dont go lean.
Old Aug 3, 2011 | 10:31 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Like said if you adjust timing and fuel I would think another 50 hp would not be a big deal since its a built bottom end. Another thing to worry about is rings butting or antiballoning plates in the converter.
Old Aug 3, 2011 | 05:13 PM
Guest
Guest
Posts: n/a
This is a good argument for a 2 stage. Bring in the first 100, then a few hundred rpm later, bring in the second 100.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
91 rally sport
22
Apr 5, 2016 05:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
