Any "ORIGINAL" 3rd gen owners who still own their 3rd Gens, we need help!
Old Aug 12, 2011 | 05:22 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Me and quite a few other members are running into a man hunt for the illusive issue of "fuel pump whine". For any original owners who still have their 3rd gens, did you ever run into the problem of "fuel pump whine" just after your purchase of your vehicle? Or did your "fuel pump whine" occur years after owning your 3rd gen. To answer this question, please reply to this thread below so that us trouble shooters can hear what you have to say about your experience. Thank you, Chevy86 IROC-Z.
https://www.thirdgen.org/forums/tpi/...ml#post5007979
Old Aug 19, 2011 | 01:25 AM
Re: Any "ORIGINAL" 3rd gen owners who still own their 3rd Gens, we need help!
bump
Old Aug 19, 2011 | 07:59 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
mine whined after i raised the fuel pressure too high one day. I lowered it and have had no problems with it for years.
Old Aug 19, 2011 | 05:44 PM
AHHh. So yours was pressure that caused the whine. Thanks for the reply ninetyone!
Old Aug 26, 2011 | 05:08 PM
bump
Old Jun 8, 2012 | 07:23 PM
dwinhofer's Avatar
Car: 1985 Iroc Camaro, 1974 type LT Z28
Engine: modified L98 corvette, L82
Transmission: 700r4, Turbo 400
Axle/Gears: 3.42, 3.42 posi
Mine never had the problem until a few years ago. I have been replacing everything electrical because I thought that was the problem. I think that when a fuel pump starts to get a loud whine it needs to be changed.
Old Jun 8, 2012 | 09:44 PM
Hey man thanks for the reply. As you can see, no one participated in this thread. But then again, not very many people are original owners.
Old Jun 9, 2012 | 01:56 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Most people probably didnt get past the title and thought it was some sort of issue dealing with documentation or something. Who would have guessed it had to do with something as common is a noisey fuel pump and pretty much nothing to do with someone being an origional owner of a car..
Old Jun 9, 2012 | 02:19 PM
zzjakect's Avatar
Car: 1985 Z28
I agree with 89EsPower. I've only had my Z28 for a year and experienced the whine. I replaced fuel pump and the whine is gone. But it doesn't matter since I'm not an original owner!
Old Jun 9, 2012 | 05:24 PM
Well as soon as my probation expires, I'll edit the title and add fuel pump issue.
Old Jun 9, 2012 | 05:39 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
What do you become after probation?` Did you get in trouble Chevy? Or is that a title for moving up in the site?
Old Jun 9, 2012 | 05:42 PM
Lol. Um. Defiance. A word of advice. Don't argue with the boss. And listen to what he says the first time.
Old Jun 9, 2012 | 05:50 PM
Engine: MPFI
Oh i thought it was just a higher rank! How long you on for? I think your question to the original owner was legit. My fuel got hot the other day after driving for about a hour running errands. It was boiling!! My next fix is all vacuum hoses and solenoid at the canister.
Old Jun 9, 2012 | 05:57 PM
Wow. Boiling? Pretty hot. Do a search up above. I made a thread strictly for testing the evap canister. I'm not sure if yours is just like an iroc's. But please do look for it. Or go to my profile and look on my "thread starter". If yours is different, I'll look for your style and post it up for you. Just let me know. I'm about to leave for a birthday party but I'll have my iPhone next to me if you have any questions.
Old Jun 12, 2012 | 08:34 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I have owned three 3rd gens and bought my first one(82 Trans Am) new. Don't know what that has to do with this. I don't remember the 82 ever having pump noise issues. Noisy fuel pump has been a common issue on all GM vehicles with in tank electric pumps. GM released a technical service bulletin concerning this several years ago. The fix was a sound deadening sleeve for the pump(you'll find these on many new GM fuel pumps and included in the kit with replacement pumps). It is a cheezy fix and helps only marginally. The fact is, when a pump gets noisy it is generally caused by resonance in the windings and is a sign of a coming failure. It can also be caused by damage to the pump rotor/case. However, I have seen pumps run fine for years with the noise before failing.
Bosch has released a new line of in tank replacement pumps that are dual stage turbine pumps rather than the OE style rotary pump. I would imagine these pumps would be less likely to become noisy, but I can't say for sure.
eightsixseven
Dec 16, 2024 01:50 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Jote4805
Aug 25, 2015 06:11 PM
neekolzun
Aug 24, 2015 04:59 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
