low oil pressure
Old Aug 13, 2011 | 12:22 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
low oil pressure
at cold the cars pressure is good and runs fine, but as it warms up when i come to a stop or idle speed, my pressure will drop to 20 or below into the red and at times with drop to 0 and kill the engine. at red lights i ahve to go into N and give it gas so it wont die. i just had a oil change on it and still no change..
91 camaro rs v6 auto
Old Aug 13, 2011 | 07:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: low oil pressure
If the engine dies with low oil pressure, then sounds like you have a bad fuel pump relay. The fuel pump relay should always run the fuel pump regardless of the oil pressure. The ONLY time this doesn't happen, is when the relay is bad, and the oil pressure sending unit takes over as a back-up circuit for the fuel pump.
If there's correct oil content in the engine - maybe the guage is off - might try a new oil pressure sending unit.
It's normal for the pressure to lower when temp increases - cold oil is thick (more pressure) and warm oil is thin (lower pressure). It's also normal for oil pressure to fluctuate while driving (higher pressure at WOT than at idle).
Old Aug 13, 2011 | 07:37 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
my oil pressure stays at 45 psi when driving and at idle its right under 30 psi is that bad ?
Old Aug 13, 2011 | 07:39 PM
OP: Start saving up for a V8 swap
92: That's more or less normal
Old Aug 13, 2011 | 10:31 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
m2b - sounds like maybe the 0 pressure at idle is a consequence of the engine dying, not the cause. Ie you have another problem.
Old Aug 13, 2011 | 10:41 PM
Guest
Guest
Posts: n/a
That can't be right. Shutting off the fuel pump, if the oil pressure drops to zero, will certainly reduce damage inside the engine.
Old Aug 14, 2011 | 12:14 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Double check with a mechincal gauge, the electronic sending units can be wrong.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
