89 L98, idles for 3 seconds then...
Old Aug 13, 2011 | 02:09 PM
jbta99's Avatar
Stalls. Fuel pump pressure is 42psi @ prime, goes down to 37psi @ idle then stalls. Just like it runs out of gas. I can hear the fuel pump run after start up. I've put new injectors in it 4000 miles ago from a vendor here. There is a Walbro pump in the tank with about 3000 miles on it.
Man I'm lost. Any Ideas?
Old Aug 14, 2011 | 09:23 AM
jbta99's Avatar
Re: 89 L98, idles for 3 seconds then...
Ohm'd the injectors, 14.9 for all. If I "pump" the throttle pedal it will stay running, if I let it idle for a couple seconds it stalls. TPS problem? Going to ohm it next.
Old Aug 15, 2011 | 07:01 PM
jbta99's Avatar
Turned out being MAF sensor.
Old Aug 15, 2011 | 07:28 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Yep. MAF's happen.
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
EFR2000
Aug 18, 2015 08:54 PM
