Crank Pulley
Old Aug 14, 2011 | 04:55 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Crank Pulley
What size of bolts does crank pulley use? I know theres 3 bolts but I know i striped one of them. Thanks!
Old Aug 14, 2011 | 07:08 PM
Re: Crank Pulley
They're 3/8". Most of them are fine thread (24 TPI) but some are occasionally std thread (16 TPI). Seems to be no rhyme or reason for why a particular damper has one or the other, but I'd guess probably 80% or more are fine thread.
Pull out a bolt that still works and match it up at the store.
Probably you'll need to Heli-Coil the messed up hole.
RS Reaper
Oct 17, 2018 07:52 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
